Trivial del brick
0 Miembros y 57 Visitantes están viendo este tema.
Hyperion
Cheeleader
Nurse
Witch
Pop star
Lifeguard
Hula danser
Snowboarder
edito: tennis player
Patinadora
Geisa
Surfera
11 chicas
EDITADO!!
Panda
Un momento, que ya habéis contestado,  xD. No serían 12, las siguientes? (Porque la india cuenta, no? X))
- Serie uno: Animadora, India y Infermera.
- Serie dos: Cantante, Bruja y Socorrista.
- Serie tres: Hawaiana, Chica skateboard y tenista.
- Serie cuatro: Geisa, Patinadora y Surfista.
En total sale a tres por serie, y aplicando mates son: 3x4=12 minifigs femeninas en total.
Por cierto Jetro, en el programa WantedBricks, también se puede ver el nombre de la pieza según Lego, es decir, el ID.
Salu2
Hyperion
¿Pero al final es indio o india? ¡Que los indios también tenían coletas!
https://www.brickset.com/minifigs/?m=col001 (nuestro indio)
https://www.brickset.com/minifigs/?m=ww016 (indio antiguo)
Yo creo que es niño :guino:
EDITO: LA PRUEBA
Tribal Hunter
"If you've lost it, I can find it!"
The Tribal Hunter is the best around at finding lost objects. No matter what you've misplaced, large or small, he can find it for you. He's tracked down the Forestman's cap-feather (it was up a tree), the Zombie's turkey leg (he left it on the sofa), and even the Circus Clown's missing pet elephant (it was behind the fridge). It's made him a pretty popular fellow, but it also means that no one is ever willing to play his favorite game of hide-and-seek with him – after all, he wins every time.
The Tribal Hunter secretly loves dancing. If he hears about a dance party, he'll be there...but he's very shy about it, so he usually wears a disguise so no one will know it's him. His most precious possession is his MP3 player loaded with dance tunes. No matter how good he may be at finding things, he's always afraid of losing it!
:lengua: :lengua:
Panda
Según la descripción de LEGO:
CitarTribal Hunter
Como ves pone "he" y no "she", asi que es un tio :D (y 11 es la respuesta correcta).
Vale, estoy de acuerdo. :D
Pero me he quedado con la duda de WantedBricks :confundido:
Salu2
Hyperion
Bueno, pues ahí va:
Vamos a retroceder un poquito en el tiempo (y en el espacio):
La cantidad de torsos diferentes de nuestros amigos sonrientes los futuron es MAYOR, MENOR o IGUAL que la cantidad de torsos diferentes que existen de los Blacktron
Saludos!!
:lengua: :lengua:
Aunque me tacheis de Don Cicuta debo puntualizar que las respuestas a esta pregunta no son del todo correctas...
Cita de: Jetro en 11 de Enero de 2011, 21:10:36 PM
Menciona tres (o más) maneras de averiguar el código LEGO de una pieza.
RESPUESTAS
Cita de: Jetro en 12 de Enero de 2011, 19:04:35 PM
2) en la página del Pick a Brick
En el Pick a Brick no están todas las referencias, en realidad hay poquitas..
Cita de: Jetro en 12 de Enero de 2011, 21:08:12 PM
El tercer método que tenía en mente es muchísimo más sencillo y práctico y se encuentra en BrickLink.
Aquí la solución del misterio: mira abajo del todo en este enlace:
https://www.bricklink.com/catalogColors.asp?itemType=P&itemNo=3001&v=2
¿Como llegar? Ve a la página del elemento y pincha en el enlace con la leyenda "View Small Images"
Ahora ya nadie tiene excusa para no encontrar el código LEGO de las piezas.
Esta me parece muy útil y no la conocía, pero también tiene piezas en que el código no está disponible para todos los colores.
Si, podeis decir que soy un quisquilloso   ^:) ^:)
Cita de: Linko en 12 de Enero de 2011, 22:37:03 PM
Adjunto un pantallazo de la versiçon de WantedBricks que he encontrado y en la que no se aprecia el número que se busca...
Jero, eres un auténtico t... xD no, en serio, es cierto que faltan cosas, pero incluso de elementos actuales hemos tenido problemas para encontrar la referencia, por ejemplo el cable conversor 9V<PF...
Además, solo tenemos los números a través de las instrucciones desde hace unos pocos años. Cualquier pieza anterior tampoco sabemos y por tanto no puede aparecer en BL.
El tercer método que tenía en mente es muchísimo más sencillo y práctico y se encuentra en BrickLink. Alguien dirá "pero yo dije Bircklink"  a lo que respondo "pero no me dijiste cómo..."
OFF TOPIC IMPORTANTE !!!
He utilizado esta opción para buscar el código ID de Lego para el Lugbulk y me he encontrado con piezas que tienen 2 códigos LEGO, no he sabido averiguar el porque, posiblemente alguno sea antiguo pero no lo tengo claro.
Si alguien utiliza esta opción para buscar los códigos para Lugbulk que se asegure en el caso de que haya dos códigos.
Gracias..., el trivial puede continuar  :)
Me imagino que será por el cambio de molde.  :lengua:
Hyperion
#596
Bueno, si se me permite, voy a autoquotearme para que se encuentre más rápidamente la pregunta y no se líe con los offtopic de encima:
Cita de: Hyperion en 12 de Enero de 2011, 22:48:09 PM
Bueno, pues ahí va:
¿La cantidad de torsos diferentes de nuestros amigos sonrientes los futuron es MAYOR, MENOR o IGUAL que la cantidad de torsos diferentes que existen de los Blacktron?
Y ¿por qué?
Saludos!!
:lengua: :lengua:
Hyperion
Porque hay dos de cada tipo  :).
